problem with autotrack
toyotatech
I have a 2003 1500HD with autotrack. I will be driving down the road and I will look down and see that the red light for neutral will be on in the autotrack switches. Everything seems fine with the truck while driving. It's just that the red neutral light is on instead of the yellow 2WD light. If you cycle the ignition key, The 2WD light will be on and it doesn't happen again for about a week.
Thank You, John.
