steering tight
hey,my trucks steering is somewhat hard to turn its nothing like my friends 04 silverado..not sure if the 4wd makes a difference??could it be i need to change the fluid??
thanks again for the help-Travis
Hey,its been like this since i bought the truck like a 6months ago(used).yeah its serviced regularly...
Thanks-Travis
Is it hard to turn both left and right? Is it hard to turn at slow speeds and/or high speeds? Any belt noise or power steering pump groaning? I'd start out by lubing the front end yourself, making sure you get the idler arm zerk that can be a pain (try turning steering wheel all the way to the right before trying) and also the front part of the idler arm which is easier if you drop the front spalsh shield (pretty simple, but makes access a breeze). You can flush the fluid, but I dont know if that would help steering effort per se.
its hard to turn both right and left,and at high speeds it perfect..theres no noises at all..ill grease my idler arm right now and see if that solves it..thanks for the help-Travis
If it's still really tight, here's a place to start looking:
Variable Effort Steering
The Electronic Variable Orifice (EVO) system increases or decreases the amount of fluid leaving the power steering pump. This provides the driver with a comfortable balance of steering wheel feel and power assist.
At vehicle standstill or at very low speeds, the system allows full hydraulic fluid flow for maximum power assist and reduced steering effort. As the vehicle gains speed, a variable orifice closes at the steering pump which reduces the pump fluid flow. This action provides a stiffer steering wheel response for an improved road feel and a greater directional stability at highway speeds.
A sensor mounted on the steering column detects the steering wheel movements associated with defensive driving maneuvers. A control module uses this sensor input and the vehicle speed in order to adjust the amount of current to the solenoid.
The EVO system consists of the following components:
The EVO solenoid (actuator) is located on the power steering pump discharge fitting.
The module that controls EVO will be located in one of two areas depending on option content:
On vehicles equipped with Real Time Damping (RTD) , EVO is controlled through the Suspension Control Module which is located behind the right rear quarter trim panel.
On vehicles which are not equipped with RTD, EVO is controlled through the Body Control Module which is located under the Instrument Panel, below the steering column.
The steering hand wheel position speed sensor is located in the lower bearing of the steering column.
The vehicle speed sensor is located on the transfer case output shaft.
The Powertrain Control Module (PCM) is located in the engine compartment on the left front inner wheelhouse.
Hey,thanks ill check into it...i greased the whole front end..it feels a little smoother it might be in my mind though..ill do a PS fluid flush then go from there..thanks-Travis
  • 4 weeks later...
hey,well now my pump is wining while turning the wheel...im guessing the pump is done for and i need a new one???or could it be an evo sensor...sometimes when im stopped and i turn left it basically groans and whines and is really hard to turn like no power is being put to the steering...not sure though i hope its not another expensive fix..thanks-Travis
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
