map sensor
what does the map sensor do ? if it is bad will my truck bog down after its warmed up when you drive it . 4.3 v-6 1996
It is the "Manifold Absolute Pressure" sensor. Basically it measures the difference between the pressure inside the manifold(vacuum) and outside pressure. It calculates load based on this and the ECU can then change timing and mixture.
Mike
