fram sure drain part #
I have the Fumoto valve on my 02, way better than the Fram Sure drain. You would need the F-107 with the adapter ADP 107. I just don't care for the Sure drain's design.
If your interested in the Fumoto valve you can get it here.
I have the Sure Drain and have had no issues whatsoever, I went with it because it has a hose with it and allows me to drain my oil without removing the skid plate.
If I remember right its the SD-4 but if you do a search, they have them on Amazon with application info. Or at least they did when I bought mine.
Oh by the way mine has been on my truck for 85,000 miles.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
