FS: Diablo Predator Programmer $300.00
Im selling a U7193 2004-'05 4.8, 5.3, 6.0 and 8.1 Predator programmer (also covers 2004 H2 and 2003-'04 SSR) for $300.00 with free shipping to anywhere in the United States. Thanks for taking the time to stop by.
U7193:
2004 Corvette 5.7L LS1 and LS6
2004-05 Chevrolet Silverado, Tahoe 4.8L, 5.3L, 6L, 8.1L
2004-05 Chevrolet Suburban, Avalanche 4.8L, 5.3L, 6L, 8.1L
2004-05 GMC Sierra, Denali, Yukon 4.8L, 5.3L, 6L, 8.1L
2004-05 Cadillac Escalade EXT, ESV
2004-05 Hummer H2
2003-04 SSR Truck
2004 Pontiac GTO
Features:
Dyno Tested Performance Tunes
Diablosport has generated dyno tested tunes for 4.8L - 8.1L GM trucks, and LS1 and LS6 cars. Average power gains are in the 15-20 HP range in the cars and 20-30 HP in the truck line,
Diablosport Performance Tunes Re-Map:
Fuel Curves
Timing Curves
Torque Management
Extend Speed Limiters (on most applications)
Extend Rev Limiters
Disable CAGS (Skip Shift)
Part and Full Throttle Shift Points
Shift Timing
Shift Pressure
Predator allows the end user to make the following fine tuning adjustments:
Timing Table (+/- 10%)
Fuel Table (+/- 5%)
Idle (+/- 20%)
Speed Limiters
Rev Limiters
Shift Timing
Shift Pressure
Re-Calibrate Speedometer for Gear and Tire Size Changes
DiabloSport Performance tunes require the use of Super Unleaded/ Premium grade fuel only, Amoco or Mobile if possible. Transmission functions do not apply to trucks with the 8.1L engine with Allison transmission.
GM Specific Diagnostic Tool
Predator can read and erase fault codes, monitor live data.
Will it still work if not running premium fuel?
Yes it will still work even if not running a premium fuel. There's a 87 octane performance tune programmed on the handheld, but you can also make your own tune for 87. Thanks
