Join http://www.photobucket.com/ and download your pictures they will give you a url address. Copy that with your mouse (right click) then when you are posting hit the IMG box right above the box where you type and it will come up with IMG tags, when you post, the picture will come.
03 Silverado Z71 5.3, Gibson Exhaust
285-75-16 BFG's on 16 X 8 American Racing Nitro's.
No T-Bar crank but alittle trimmin to make em fit.
How do you guys think they look??
I have mixed opinions.... :cheers:
Brent
That's 100 times better than any I've seen with 20"+ rims !!
Looks good! More like a truck than a matchbox !!
What is it about them that you have mixed feelings on ?
  • 11 months later...
my07silvy, you have a really nice truck, thats one of the few 07.5s i actually like. To the OP, the front stance looks nice, but IMO it has too much sidewall showing. I think it would look a lot better with a set of 18s or so.
mixed opinioins!?!?!? :flag:
your truck has that "get the he## outa my way" look to it, she's sittin big makes her look more like a truck props man!!! nice truck!
steve :driving:
thanks 99 silverado, I just picked it up last thursday. I was hoping to get the 6.0 but was having trouble getting one around here....My 5.3 has a considerable amount more power then my old ones did, thus having aluminum block, 315 horse and 340 torque....I do have 18 inch wheels if u were talking to me???? I have 24's but haven't put them on yet!
No i was talking to the OP that he needs 18s with same size tires. I think your 07 looks great with the stockers, the 24s might be overkill, but thats my opinion. I like the fancy stock (LT, LTZ, etc) look of most things.
hey I'm trying to figure out how to make the picture smaller...no luck yet....Also I will Take a new one with my tinted windows as soon as the rain stops and I WASH IT AGAIN!!!!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
