Eclipse 6600
I am considering installing an Eclipse 6600 in my 2006 Sierra, replacing my factory radio. My goal is to get Nav, DVD movie sharing with headrest DVDs and IPOD integration.
What I don't want to lose is my factory Onstar and steering wheel controls. Can anyone offer advice in support or against this plan? Thanks!
Crutchfield sells the harness for about $100, simple plug in line.
i have an eclipse cd3000 deck and it has the program built in to recognize steering wheel buttons. Now i just need that steering wheel lol. If yours doesnt have it thats just sad but play with the menu it should.
Hey! keep us updated on how this works out for you, I am planning on doing the same thing in my 06 sierra denali(I am not sure if denali package makes a diff)... How much did u pay for the 6600?
  • 3 months later...
i'll be doing very similar with my 07 yukon...i have the bose system (thought it was speakers only) but realize i'll be changing out amps too...will lose rear control from what i read also...
eric
yes you can keep onstar and bose with the metra gmos04 harness i believe 100 dollars. and retain steering controls with the pac swix- eclipse adapter. i have a 5495 and have done this. is fairly siple if you know what youre doing, but works fantastic. hope this helped.
  • 6 months later...
:confused: Hey can someone tell/show (w/ Pics) me how to install my PAC SWI-X steering wheel control adapter. (07' sierra classic) The problem is the instructions saying that I need to use the plug @ the steering wheel rather than the plug @ the stereo. Everything that I have in my truck, inside and out, has been installed by me. I admit defeat and any help is greatly appreciated. :fume:
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
