06 GMC 1500 WT Wanders
Picked up my new Sierra a couple weeks ago. Regular cab, long box, 2 wheel drive. I notice the truck seems to wander at speeds above 40 mph. Is this something I have to just get used to? Maybe something I can look at? Possible the shocks are really as lousy as I hear? Dealer had 38 lbs in the tires I lowered the pressure to 30 lbs and noticed no difference.
Thanks
Bob
What kind of tires are on your truck? My 06 Sierra crew cab, 2wd, short box has 245/70R17 General Ameritrac they wander all over the road also, you have to pay close attention or you will be across the line or off the road in a second. I had a similar experence with my daughters Yukon XL, the original tires had worn badly on the inside fronts so she went to Wal-Mart bought two new Goodyears. I drove to Dallas about 300 miles 2 lane and 4 lane had the vehicle wander all over the road. When I returned home I went to my tire shop and they said it was the tires, put on 4 new Firestones, problem solved. Disclaimer, I do not work for Wal-Mart or Firestone.
I had the same problem and mine was incorrect toe alignment. Anything out of spec causes twitchy or wandering truck. I am assuming the parts are not loose and worn.
Ken
The truck has the factory General Ameritrac tires. No worn or loose parts as the truck is brand new, just turned 700 miles today. It would really suck if the tires are the problem. I think i'll go the easy route first and have the alignment checked.
What ply tires are they. A friend of mine had a 2500 work truck that had just had its tires replaced when it started to wander all over the road. Turns out the tires were replaced with 8 ply instead of 10 ply. Once the 10 ply were put on the problem went away.
GMC called me today.... Sunday at 3:00 :cheers: They asked what I thought about the truck, told them of the wandering problem. They asked if they could have an engineer contact me. Glad to see they are concerned enough to contact us. :gmc: I guess we will see what shakes out. :mad:
I have the same truck as you with the same Generals. Only difference, on the first day of ownership, I changed the wheels to OEM 17" GMC alloys that I hade mounted and balanced at my local Discount Tire. My truck doesn't wander.
Lou
I've got the Chevy version of your truck, and no wandering at all.
I've never had GM contact me though, by phone or mail asking how the purchase went, and I haven't received any satisfaction surveys from when I had the truck in because the tires were falling apart. The dealer I bought it from did send me some coupons and a can of touch-up paint though.
What's really strange is last week I recieved via mail, the GM purchase survey. I filled it out and sent it in. I have not returned to my dealer nor have I discussed the issue with them, as i'm not big on any dealer (even with warranty) touching my vehicles (this also includes my vette) I have no idea if this was just a random call, or it's something that GM is now doing on new purchases. I did find it very strange that they contacted me on a Sunday afternoon. Either way, they now know i'm having an issue. I'll give them this week to contact me and then i'll have the alignment checked. As for the dealer, I got touch-up paint and another set of center caps for the rims, both at no charge. Dealer was excellent, great price and eager staff even though I had the GMS discount. :uhoh:
I have received the GM survey also by mail.
    250.3k
    DjmFingerstylePlayer
  • Who's Online   4 Members, 0 Anonymous, 655 Guests (See full list)
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
