Headlamp removal
I have a '96 Sierra (Silverado) with the plastic headlamp lenses, NOT the sealed glass lamp. How do I remove them to change the bulbs?
All I see is two Torx head screws on the top which are accessed thru holes in the top.
The shaft on my Torx driver is too short to reach them.
Thanks, Jerry
:gmc:
There are two L-shaped bars that you just turn and pull out...The headlight should fall right out, then you just unplug the light.
Are they the kind you just put the bulb in the back? Look behind the assembly and see if you can turn the bulb assy about 1/4 turn. The bulb should come right out.
