Brake upgrade
I am looking into changing out my front discs from stock to slotted, anyone had experience with this ie. does it make a difference? I am looking for better braking performance while towing...don't tow anything heavy enough for a controller to be added, but just looking for better brake performance all together. Not looking for drilled and slotted (heard they crack fairly easy) but just a good quality slotted disc with good shoes. Any input would be appreciated. :gmc:
well of course they help when you are breaking with regular rotors there is gas that is trapped inbetween the rotor and the pad making a cushon of gas inturn not stopping as well with slotted rotors this gas can escape by the slots creating the pad to contact the rotor much better and making better braking performance
Chris, we (CARQUEST) sell a Severe Duty rotor for Ambulances, taxis, police cars etc and it is drilled. To my knowledge, we have never had one crack or fail.
Not sure if they are avail for your truck and they are pretty costly. You can definitely feel and see the quality when you pick one up.
I am not sure how much they would help you. They are designed for severe duty and heat. If you are not working your brakes that hard, I would doubt you would see a lot of difference.
Be sure to replace your pads too. I didn't replace my rotors but I did replace my stock pads with Hawk Performance and it's a night and day difference. When I put the 3" BL on my truck I also put new rims and 305's on so to compensate for the rim/tire increase I upgraded the pads and it was a total 180. Much improved.
PraiseDyno are my favorites for an upgrade in performance over oem. Cryo treated slotted rotors and cryo pads with a much higher coefficient of friction than oem. Significant improvement in braking even if you just did the fronts.
Going with a store brand, I would lean towards PowerSlot rotors and Hawk or Raybestos ceramic pads. Also consider stainless steel brake lines and a good bleed.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
