R&D Headlight Controller
EDZ,  Those controllers work great. But a
little pricey at 80 bucks !  Tom has one on
his truck and reports it works great. But if
your cheap like me check out:
www.lights out.org
Free advise to turn off auto ons and DRLs!
Used their hints to turn them off in my 01
and my Caddy !........geo
I have an R&D, but with hindsight being 20/20, I would get the Kennedy wiring harness. some posts.
With the Kennedy harness, you don't get any dimming as the new harness can handle the increased amperage/current flow that the stock wires don't.  Kennedy Info
That one should work on your Avy.
I have the R&D one like Geo mentioned and it woeks fine, with out dimming.  Before that one, I had one from Stylin Concepts, and when the high beams came on, you could see the low beams dim noticably.  The R&D kit hasn't done that, so far, after 1 - 1 1/2 year of use.
I'm sure that the Kennedy light setup is a great kit though.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
