Is your Rear End Lop Sided?
Ok, I dont know if any of you have seen this...... I was cranking my tbars a little yesterday, going for that vanity inch... and was wondering how close i was to complete level with the back of the truck. So I measure the back end right at the wheel wells, and the driver side is 1/2" lower than the passenger side. What the hell, has it always been this way. I know that I have a 1/2 tank of gas, but would that make a difference? I came to work this morning and mentioned that to my co worker who has had and has gmc sierras, he noticed the same thing. Especially when he had new tires and leveling spacers put on his 06 ext cab 2wd. Anyone know if this is normal? You may want to measure your trucks.....
Thanks, check the air pressure in the tires.... its good, and what would chassis height have to do with it, I know that the body mounts on each side should be the same height....? Are the wheel wells bigger on one side???? The gas in the tank was my first thought, i'm gonna check it again when its empty. Just wondered if it was a common thing. And lol, maybe they did do this on purpose.....GM conspiracy.....lol
If your fender heights are within 1/2 ", I would be quite happy. I bet that is within reasonable spec. I look for parallelism between front of box to rear window with truck on a level slab. Personally, I hate body twist.
Ken
All MFR's spec's & measurments are by the chassis not the wheel wells. Too much variations in the body & everything is based on the frame just like a house footings are the base of a house.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 330 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
