Gm codes
Mike Haynes
Truck has rough idle in park and bogs down when in gear. I have changed fuel pump, fuel filter, and the air idle sensor that screws into the side of the throttle body just in front of the egr valve. It dosent want to shift when under a load. 65,000 miles. :cheers: I also replaced the cap & rotor I need some more advice. I just replaced the EGR valve and that didn't do anything either.
