FS: Extang TriFecta Tonneau Cover - Crew Cab
rmreid
what exactyly kind of cover is this or i should say how does it work, the tri fold?
Hope this helps:
3-piece folding design of the Extang Trifecta provides fast access to your entire truck bed
The Trifecta Tonneau features a heavy-duty black vinyl tarp that’s expertly sewn to solid aluminum frame sections and cross bows
Uses spring clamps to latch closed at the tailgate for a secure seal
The Trifecta Tonneau’s smooth design looks great and improves gas mileage
Tough luggage-style clip straps secure the Trifecta sections at the cab when open
The Trifecta ships fully assembled and ready to install in minutes using the included clamps—no tools or drilling required!
Extang Trifecta Tonneau Cover is backed by a 10-year tarp warranty; Lifetime Warranty on the aluminum frame
Description:
With an easy to use folding design, smooth looks and great durability, you’ve just hit the Trifecta! The Extang Trifecta Tonneau Cover is a workhorse at covering your cargo, with a heavy-duty black vinyl tarp that’s expertly sewn to 3 folding aluminum frame sections. Drive with the Trifecta fully closed or wide open—tough luggage-style clip straps hold the folded sections in place at the cab.
The Trifecta ships assembled and ready to install right out of the gate. With the durable clamp design and simple instructions, there’s no clumsy jockeying for the right position on your bed rails. No tools or drilling required!
Extang’s legendary tonneaus were born as purebred racers, track-tested on some of the highest horsepower trucks made. Their sleek design makes for excellent drafting, and improved gas mileage. Plus, the reasonable price is easily covered by a good day at the ponies! Lifetime Warranty on the frame; 10-year tarp coverage.
Notes:
Under-the-rail bed liners do not need modifications to accommodate the Extang Trifecta Folding Tonneau Cover
Over-the-rail bed liners will need to have minor cutting done to accommodate the Extang Trifecta Folding Tonneau Cover
We cannot guarantee that the Extang Trifecta Folding Tonneau Cover will accommodate non-factory stainless steel Bed Caps and Bed Rails. Some modification may be necessary to install the Tonneau Cover.
would you ship this cover out at all, i am from wisconsin, zip code 54902, just checking becasue i am not even close to pick it up, so please let m kenow asap.
Thanks,
Troy
Thanks,
Troy
Troy
Let me check as I don't have the carton to ship it in, so I would need to get a carton made, let me check tomorrow or Saturday at the latest and I will let you know.
Thanks :ughdance:
Bob
Thanks,
Troy
Troy
They had to make a shipping carton out of 4 boxes, plus bubble wrap came out to $26.50 w/tax.
Shipping was another $29.33 for a total shipping cost of $55.83 plus the $175.00 = $230.83
    ncleg
    ncleg
  • Who's Online   1 Member, 1 Anonymous, 1,371 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
