Bank of America 500/Oct.
CapitalTruck
Anybody going to the Bank of America 500 at Charlotte on October 14th? Think we could get a gm-trucks.com tailgate thing going?
I'm going,Along with 7 other friends and family members!
Been going to this race since 1994 when it was called the Mello-Yellow 500.
  • 4 weeks later...
Hey Mike,Why don't we try to hook up while your down here?
You all camping? Three friends and I are coming down Friday night and staying through Sunday, Rock City campground. I got a fee schedule for portable toilets...do we have to get one of those? (or are there public restrooms in the campground?)
Either way, we should all crack a few beers together somewhere.
Sure I wont be there on Thursday but ill be at the track Friday and Saturday.
No,We're not camping,We usually get to the track on Saturday morning around 11-11:30,We fire-up the grill not long after that and just tailgate all day 'til about 5-5:30 and then head into the track.
Can't answer your question on the restrooms for sure but I don't think there are public restrooms there,Just lotsa' porta-johns!
I know where Rock City campground is,Its on Speedway Blvd.,almost across the way from Tom Johnson's camping center,Your going to be far away from where we are,we park off of Morehead Rd. up from Hendrick's race shop.
Check out this map....Lowe's Motor Speedway parking map
If you look on the bottom-left,where its aqua in color,thats where you'll be,now look to the upper-right just a little,where its green in color and says "NON-SPEEDWAY DAILY PARKING",thats where I'll be,It looks like we can just walk over to each other but we can't,that white thats around us blocks us from walking to each other,there are houses and fences that block it,we would have to walk a few miles around to get to each other.
If you want to try and get together I have no problem with that,sounds like fun,I just wanted to let you know that it might be a walk!
By the way,have you ever been down to Lowe's Motor Speedway before?
Later,Rich
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
