wiring diagram
k_bennett
I curently have a 1983 silverado that i have wiring problems with. I was hoping that I could post this on here and somebody could help me out with a wirring diagram, or anytype of help. I would appreciate it a lot.
basicly I need any help that you can give me, but i was mainly hoping for some type of diagram that i can look at while trying to hook everything back up.
I've got wiring diagrams for that truck, but I need to know what you are doing so i can get you the diagrams you need since there is about 40 different wire diagrams for that truck
Well wat i am doing is I took the wiring harness out of the inside of the truck becuase they were all cut and there was suposivly a short. So I had went to a salvage yard and got a hole new harness and now I need to figure were all the wires go
check your messages my # will be there, call me some I can get a better idea of what harnesses you are replacing. and we can figure out the best way for me to get you the diagrams
  • 4 months later...
Here is what i have on an 83:
1983-87 GMC C/K Pickup Security Information
Constant 12V+ Red Ignition Switch Harness
Starter Purple Ignition Switch Harness
Ignition Pink Ignition Switch Harness
Accessory Orange Ignition Switch Harness
Tach White Coil
Brake Switch White Brake Switch
Trunk Pin n/a
Parking Lights Brown Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger White (-) Driver's Pin Switch
Door Lock Light Blue Driver's Kick Panel
Door Unlock Black or Black/White Positive Trigger
Horn Wire Black (-) Steering Column
1983-87 GMC C/K Pickup Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Front Speakers 3 1/2" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 4" x 10" Rear Kick
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
  • 2 months later...
www.helminc.com
This is a source for diagrams, but they are pricey!
    todd wollemann
    todd wollemann
  • Who's Online   1 Member, 0 Anonymous, 583 Guests (See full list)
