CT/NY/NJ: Looking for Rear Bumper (05 3500)
Ted_Grevers
Helping a friend out who mashed the rear chrome bumper on his 05 3500. If you have a rear bumper that you're selling, I'll let him know. He will need the mounts too. I'm guessing someone may have installed a rear roll pan, and has a rear bumper left over. He's in Stamford, CT, but drives throughout the tri-state area for his employer.
Thanks for looking...
-t
