fuel pump
mikeval
Hello GM tech, just signed up and was wondering if you might be able to give me some information. Has GM come up with a quiet fuel pump for my k3500/ 2000/ 7.4. it works fine just annoying. Thank you Michael
Nothing special that I know of. You probably have a bad pump because they're not usually noisy. Sure, if you stand outside the truck in a quiet area, you MIGHT be able to hear it, but you shouldn't hear it inside the truck even with radio and A/C off.
Thanks for the replys to my question. I've only had the truck two months and might not be used to all the different sounds. I really enjoy reading all the forums, thanks Mike
You might want to change your filter. I have seen clogged filters increase pump noise but usually the only way to stop it completely is to replace the pump.
^^^^What he said,,,, I had the same problem and i changed my filter and noise went down dramaticly.
my brothers 1990 1500 had a loud fuell pump as well. But it soon failed on him. The noise may be a sign that it is going out.
Thanks to all that answered. Right now the filter seems like the easy fix. Will let you guys know what happens. Mike
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
