Extending camper mirrors
captain6liter
I extended the mirrors on my truck to wash it .Now the r/s will not retract.The motor is working and I have cycled them numerous times.I have folded the mirror in+out several times with no luck.After retracting the mirror manually you can see that the mirror wants to move Does the motor need to be replaced ?
C6L
This may help:
Document ID# 1768139
2006 Chevrolet Chevy C Silverado - 2WD
Subject: Outside Rearview Mirrors May Blow In At Highway Speeds or Power Folding Feature Appears Inoperative (Synchronize Mirrors) #03-08-64-010B - (02/22/2006)
Models: 2002-2006 Cadillac Escalade, Escalade EXT
2003-2006 Cadillac Escalade ESV
2003-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2006 GMC Sierra, Yukon, Yukon XL
2003-2006 HUMMER H2
This bulletin is being revised to add the 2006 model year. Please discard Corporate Bulletin Number 03-08-64-010A (Section 08 - Body and Accessories).
Condition
Some customers may comment that the power fold feature of the mirrors either does not operate properly or that the mirrors may blow back toward the closed position at highway speeds.
Cause
Manually folding the mirror may cause the mirror and the motor to become out of sync.
The power mirror drive has detents in the drive hub that lock the mirror to the drive system. This system is designed to let the drive hub disconnect without damage through manual input to the mirror. This mechanism allows the mirrors to be folded by power but still have the break-a-way feature if contacted accidentally.
Correction
There are no replacement parts necessary to correct this condition. The mirrors will self-synchronize by following the procedure below. Once synchronized, the mirrors will function properly unless folded manually.
Important: Prior to replacing a mirror, attempt to electrically fold and unfold the mirrors a minimum of 3 cycles.
Set the power mirror selector switch to the center position. You will see the mirror directional control switch illuminate the power folding symbol.
Press the right or left side of the directional control to fold or unfold the mirrors.
Cycle the mirrors open and closed 3 times. The mirrors should now operate normally.
Please advise the customer of the above procedure for future reference or provide them with a copy of this bulletin.
This may help:
Different problem altogether. The folding problem occurs if you fold the mirror in manually and it loses its detent. Cycling the mirrors in and out electrically a few times fixes that problem but would have no effect on the camper style extending/retracting feature.
    Kirk Belch
    Kirk Belch
  • Who's Online   5 Members, 0 Anonymous, 1,328 Guests (See full list)
