Oil Filter Adapter ??
I have a 96 GMC Suburban, 4x4, 7.4L. In the rebuild process I am replacing the Oil relief valve that goes between the block and the oil filter adapter. Does anyone have a diagram that shows just how this thing fits ? The new metal one (from GM) is not the same as the plastic original. GM says the metal one is good from 78-04.
