true flow air fiters
If you have an intake tube you should be good, but Ive never heard of problems, nothing major anyways. If a sensor gets clogged its from over oiling the filter. (probobly)
My truck had a drop in stock replacement K&N, i cleaned it and it works fine so far
  • 4 months later...
My truck had a drop in stock replacement K&N, i cleaned it and it works fine so far The true flow is a better filter when properly oiled IMHO.Kand N is just overpriced old tech.
No issues and over 1 year with mine. Their oil contains a "tacktifier" glue like substance so it stays on the filter and off your MAF.
I have done one oil analysis and will do one more. I then will do the same with a Wix to see if the TF is really as good or better than paper.
