Hesitation
kokanee
I have a hesitation problem when the engine is cold on a '99 5.3 Liter. I have also noticed my temperature gaguge appears to be out as well. When I first start my truck in the morning after it has sit all night the temp gauge is already showing 75 degrees (It has been around freezing temperature outside)
I have done the test with voltages/temperatures off of the engine temperature sensor. My truck is Canadian so temps are in Celcius.
Minutes of Test Resistace of ETS Voltage Temperature (Instrument Cluster)
0 2.06K Ohms
1 2.1 75
2 1.53 75
4 0.9 76
4.5 3.545 76
6 3.375 78
7 3.1 81
10 2.8 84
20 2.42 87
35 2.041 94.5
35 231 Ohm 94.5
The first and last readings were taken with the engine off. 94.5 degrees appears to be normal operating temperature.
Do these numbers look normal?
Did you have the sensor unpluged when testing for ohm values. If not retest it again with it unpluged. With the sensor pluged in you will not get correct readings.
I mainly need to know what the resistance is when it is cold or same as outside temp.
Yes, the sensor was unplugged for the OHM readings.
The first ohm reading was when the engine was cold (2.06 K Ohm)
The second ohm reading was when the engine was at operating temp (231 Ohm)
I'm sorry, I was out of the office for a few days and forgot to reply back to you.
With the readings you have the ect sensor is out of spec and would cuase hesitation
At freezing or 0 °C the OHM reading should be around 9420 OHMS or 9.4k OHMS
Here is the chart
Temperature vs Resistance Values (Approximate)
°C °F OHMS
150 302 47
140 284 60
130 266 77
120 248 100
110 230 132
100 212 177
90 194 241
80 176 332
70 158 467
60 140 667
50 122 973
45 113 1188
40 104 1459
35 95 1802
30 86 2238
25 77 2796
20 68 3520
15 59 4450
10 50 5670
5 41 7280
0 32 9420
-5 23 12300
-10 14 16180
-15 5 21450
-20 -4 28680
-30 -22 52700
-40 -40 100700
