How to get unstuck
jefffoxsr
I was stuck in a little mud this weekend. Bad timing as I received a call that my wife was being rushed to the hospital for emergency surgery. She was near death, but is ok now.
I am replacing the stock tires this week with Bridgestone Revos
I ordered a 48" high-lift jack with all the accessories today.
I was stuck in a very small amount of mud, but the soil was soft because I think it was a farm field.
I tried to jack up the truck and put some 8 foot long 2" x 6" under the tire to drive out.
The boards provided NO traction, so I couldn't drive out.
My friend got stuck trying to pull me out with a tow strap.
No trees around, and no winch anyway.
I won't be buying a winch as I never offroad, but I want to be better prepared if I ever get stuck again.
Questions:
1. What else can I put under the tire for this situation that would allow for good traction?
2. Would a come along help? I have a 2 ton one that wasn't with me at the time.
3. What else can I do in this situation?
4. Are there any videos or online sources to tell how to get unstuck?
5. Do you know of any 4x4 or offroading forums that I can go to and do a search?
Thanks.
ive heard wonder stories about kitty litter undertires, but i am skeptical of that and its expensive, just bring bags of sand
i broke off a refridgerator door off a fridge that had been thrown out into the woods and used that :D
there are the basics:
have a friend jump up and down on ur bumper or above the tires in the bed when you are on the gas trying to get out
drive reverse drive reverse drive......
i have been with people, when their front tires are stuck, to switch the truck down to 2x4 if you have that option, so that ur fronts dont spin aimlessly and dig in further.
Rocking the truck as stated would have been a good option. Also if spinning the tires doesn't dig you down deeper spin them enough to clean the treads but not so much to dig deeper.
A 30 foot 3" snatch strap (or 2) is what I use.
Tow straps will have hooks, and are OK for pulling a buddy down the road, but off-road calls for a snatch strap. This kind of strap will typically stretch about 20% of its length and has loops (not hooks) on each end.
If you can get a friend on solid ground, hook up the strap and make about a ten foot run at it before the strap gets taught. The weight of your buddies vehicle and the stretching action acts like a rubber band and "snatches" you out.
You might need to make a few runs at it, and you want to make sure you are on the gas when that strap gets tight so you have your wheels moving when you pop up out of the holes your in.
Hope that helps.
Steve
Thanks.
I did order a 30 foot strap today from summit racing, but I don't recall seeing the word snatch there.
I ordered the one with hooks.
How do you attach the ones with loops to the trucks?
Where can I get one like you described?
Thanks.
Like I mentioned above, the ones with hooks are not good for yanking on. If the hook comes lose, it can become a projectile.
I have a 97, and my hooks in front are open so I can slide the loop right on. In my signature you can see the receiver shackle bracket that I made to hook up the rear.
Sometimes these straps are listed as "recovery straps" we have always called them snatch straps.
Here is a real nice one at summit:Pro-comp Strap from Summit.
Hope that helps.
Steve
usually 4 wd, or 4 low if need be, and the hammer down gets me out.
Rock it drive /reverse, repeat at first to get some motion. Actually starting out slowly throttle up on the gas pedal helps me get traction too, usually snow or mud. Once you get moving DONT STOP, FLOOR IT!
( That has especially worked when I was pulling someone out, Just flooring the pedal at first got me no where!)
I usually dont use straps if I get stuck, Ive never had a chain break on me
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
