VDO oil temp. gauge
FJB20
Want to put an additional (Oil Temp.) gauge in my 2001 5.3L Silv.
Don't really want to weld a sending unit in the oil pan. Is there an easier way - sending unit hooked to the oil filter etc ??? Heard a few ideas but not reliable info.
Thanx!!!
Thanx!!!
I have seen sending units that replace your drain plug
Good idea but how do you change the oil on a regulat basis. I was hoping for someone who had installed the oil temp. with other than drilling onto the oil pan etc. Thanks
the sender i seen just screws in to the extisting threads on drain plug and has a wiring connector on it you just remove sender to drain oil
    Aries68
    Aries68
  • Who's Online   4 Members, 1 Anonymous, 522 Guests (See full list)
