4wd switch not working
My 99 Yukon is stuck in 4 wheel drive. I'm assuming it's the actuator but I need to know if there is something that will tell me for sure.
When I hit the button to take it out of 4wd I can here the actuator trying to do something but the light will just blink and than go back into 4wd or auto 4wd.
Anyone have any advise?
Tim
  • 2 months later...
If you haven't had this fixed yet... I had the same problem not going into 4x on my little Blazer, the problem was a $40 vacuum modulator that was located under the battery.
--Mike
My 06 GMC Sierra, with 528 miles on it would not get out of 2wd. Only flashing lights on the switch. After 2 days at the dealership, and replacement of the encoder motor, it turned out to be loose connections on the fuse block!
There is a common problem with the pushbutton assembly on the dash, the solder joints for the switch were cold soldered and tend to crack and make very poor connection. I fixed this on my buddy's truck with a quick reheat and reflow of solder. If you feel confident enough to pull the switch apart and resolder it this might work, or I think a new switch from GM is around $50 or $60 dollars but you may eventually have the same problem.
  • 4 weeks later...
    250.3k
    Old Bay
    Old Bay
  • Who's Online   5 Members, 0 Anonymous, 671 Guests (See full list)
