07 silverado
cerbomark
I only find two front end grease fittings. They are at the ends of the tie rods I believe. Rest of what I see looks sealed with no plugs for fittings. Is this correct? Why? Thanks
anyone?
No idea. I'm not a lube guy (we have a dedicated lube guy) and haven't really looked at one to see how many fittings there are. Since I'm not currently working, I can't even ask the lube guy.
  • 3 months later...
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
