My day went from bad to worse
General Lee 01
Well i came in to grab touch up paint (scratched in between the bedliner and tailgate where its not sprayed the other day)
It was sunny when i came in.
Go back out its dark out and its raining.
I just washed my frickin truck too.  I cant win.
Ill try again tomorrow
I know how you feel.. Especially with a black truck..  I hate just after i wash/polish it pours rain..  Its like someone up there hates clean vehicles...
Steve
black truck?
Mines blue but its the same difference
You're out washing your truck and you spy a bird on the power lines and you just know the bird is waiting for you to finish up, all the while the bird is saying to itself "Mine, all mine!"
MY problem is the cat.  White truck.  Know what a white truck looks like with cat prints all over the hood?  Never see them until the morning after the wash and I am leaving for work.
Truck wont fit in the garage?
Wonder if my parents will let me do some renovating?
Yeah, those durn cats put paw prints all over my pickup.  They make imprints in the dirt and let the paint show through!
I dry the truck also.  Still doesnt help because the cat has this way of finding the puddles immediately before the jump on the truck....
ROFL!!
I know what ya mean
Jeff
Took me five times reading that post to finally get it!!! LMAO...!! DUH......!:shocked:
(Edited by NewbieZ71 at 11:43 pm on Aug. 19, 2001)
1 a hate cat prints so i know how it feels 2 isnt it like newtons law that when you just finish washing your truck it rains out... it happens to me just about evey time down here in new orleans
illmac - I remember New Orleans (and Baton Rouge)growing up....you shouldnt have to wash your truck in August....doesnt the condensation and humidity constantly running off  keep it clean all through the summer???:wink:
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
