Door problem
chevyPwns
Hi all! i have just bought a brand new silverado 2006 :cool: its fully loaded 4X4.. well any ways iam really happy with the truck... but i have one major problem the truck i got was off the show room floor so i think this might be the cause... the drivers side door raddles alot.. when going over train tracks and bumps and such.. the passanger door does not make a sound!! so i think it was from all the people opening and closing it in the showroom floor... so is there a quick fix for this?? or do i need new rubber molding on the door what do you think?? Thanks in advance
