How to check the differential oil
Neat trick from the service manual. With vehicle level, remove the oil fill bolt. Take a 6" pipe cleaner and bend over the end the distance the oil should be from the drain hole. (on my 06 yukonxl denali with the 8.5" axles it's .5 inch) fit the pipe cleaner through the hole and lay it against the bottom of the hole with the bend facing down. Lift the pipe cleaner back out and if it has oil on it your diff is full. If not you need some lube. Add lube until full, replace drain bolt and torque to 24ft/lbs. BTW, my rear diff was down 1/3 qt. My front axle has a drain bolt so I just changed the oil and refilled.
(I used a marine hand pump for outdrive oil to pump fliud into the differentials. The pump fits right into the GM 75w90 lube bottle and is available at any West Marine, Boat US or some WalMarts.)
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
