2000 S-10 Blazer 4-door.
Hi All,
Has anyone else experienced issues with the rear washer fluid line leaking(inside the rear of the vehicle)? Any tips/tricks to fixing this..... just start cutting and splicing hose(s)?
Thanks,
-John
The hose is routed up driver's side rear pillar, across the top under the plastic panel and then through the grommet into the rear hatch. I'd bet the line is cracked where it goes into the rear hatch.
I removed the plastic panel and found the line to be cracked just before it enters the grommet to the hatch. I cut the cracked section of tubing and spliced in a short piece of vinyl tubing in its place and it is good to go.
Thanks,
-John
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
