Supercharger for 93 Pace Truck??
I have a 93 Pace Truck(350 TBI) I am looking into the option of a supercharger, I am wanting to see what other people have done and learn from them as to options of brands. I have a 88 vette block that I am going to use as a starting point for the new 350 rebuild(mine has 166,xxx) on it now. So what is on the market and what are your experiences??
