2000 Z71 Problems
Ok I have 2 issues that I hope somebody can help me out with.
#1 I am hearing the sound of water splashing around over on the passenger side of the cab. I still have heat and the floor is not wet and I don't smell antifreeze and sometimes when I park the truck I see water dripping out from just under the passenger side of the truck. It is clear water but I can't see where it is comming from.
#2 I m getting a squeek from the air conditioner belt.I have changed the belt and changed the tencioner and still I get the squeek.I have tried belt dressing and it made it worse please help.
Thanks Tim
For item 1 I have no clue.
For item 2, I had the same problem with my 2000 S-10 (V6). I also tried a new belt and tensioner and the squeak remained. I also made the mistake of trying the belt dressing and it also made the squeak much worse.
Turns out the squeak was in the AC pulley/clutch. I opted not to fix it as it was just a noise and I was trading in the truck on a new Sierra. I did spray some silicone in and around the A/C pulley clutch and that would quiet things done for a while, long enough for the dealership not to hear the noise.
Air in the cooling system is most likely.
This oughta fix it
This oughta fix it
Thanks It worked
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 861 Guests (See full list)
