Catback exhaust,
OEM system showing signs of wearing out,
Need suggestions on a nice mellow sound, complete system, uses stock hangars, exits behind pass side rear wheel to prevent damaging 24 inch camper overhang and 68 Camaro on trailer.
Stainless steel is nice, aluminunized steel would be a good second choice, some have said Gibson sweptline is good, but,
Truck is '88 Chev C3500 Dually 454/Auto Std cab long bed
Thanks for your suggestions, Everett
I'm a DynoMax person myself.  DynoMax has a nice, mellow tone, but yet is just loud enough to sound good.  It's not like Borla or Flowmaster which tend to sound "raspy" or like a bunch of rocks rattling around in a tin can.
Gibson sorta bridges the gap between Flowmaster and DynoMax in my opinion.  It's a little louder than DynoMax but not as raspy as the Flowmaster.
B&B is also a very mellow tone, but I don't think they make a system for your '88.
Checkout;
www.Dynomax.com or www.a-1performance.com for DynoMax complete fit listings.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
