Just Wanted To Show Off A Little Bit
ShakinLM7
I'd be interested in a deal on any performance parts if anybody has something they are looking to get rid of. I have some NICE car audio & video for sale or trade. I currently only have cat back duel's with duel chamber Flowmasters. I'd realy like to finish that up with a good set off long tube headers. I have the K&N as you can see from the pics and the Hypertec Power programer 3 that I'd like to replace with a good engine managment program and a lap top if anybody has any sugestions on any of that it would be appreciated. Im just not realy happy with the limited options the hypertec gives me. :cool: lol!
Merry Christmas All!!
I have dropped it a total of 5 inches in the rear and 3 inches in the front with drop spindles and stiffer coil springs that are the same height as the factory springs. I really don't have any problem's with bottoming out unless I am driving recklessly :confused: and hit a big dip or bump in the road. I have some other stuff done to the suspension and it holds the road like no other!
Michael, I have to know more about the shaker scoop and that "aluminum" looking piece just to the right of it. (passenger side)
This has got to be the scoop off a late 70s or early 80s Trans Am. I had a 77 TA and the shaker scoop looked exactly like this.
Tell us more about this.
I may cut a hole in the hood of my Wife's Yukon XL LOL :cheers: . Not unless I want to be sleeping in it.
Nice truck, i really like that shaker hood setup.
Couldn't agree more....it does look cool! Need more info.
Thanks a lot guys! :) I've wanted a TA with the shaker hood since I can remember, so when I saw the hood for the first time I fell in love. I have been trying to find someone who sells it since before I bought it. For a while I thought it might be a custom but about a week ago I found out its made by Keystone GoodHood. You can buy the non-functional for about a thousand dollars or get the functional which is around $400 more. Its all fiberglass and fits like It was made by GM.
I may cut a hole in the hood of my Wife's Yukon XL LOL :crackup: . Not unless I want to be sleeping in it.
The aluminum looking peace that I think your talking about is where the air flows from the shaker into the hood through. The hood is hollow and routes the cold air up to the K&N. You can see a little better in this next pic. I also threw a few pics of my interior in.
This is the stereo set up I had last year. the spring break girls LOVED IT! I had a little sticker made that said Vibrating Bed 25 cents for 10 min with a little coin slot printed next to it :)
Man, I really dig the 2 tone seats. I want to do something like that one day, when I get the money. :)
EDIT: BTW, about how much did it cost to get that done, I think it's pretty sweet.
  • 3 weeks later...
so, my question is, what are the benefits of the shaker as oppose to the stock setup? is that the actual intake now?is it like cowl induction? the same? it looks really cool and ive always liked the cowl induction look- but i would only get it if it was functional.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
