resistance when in 4x4
Applied the 4x4 on a snowy day and it appears that I have a huge resistance the 4x4 works but for some reason the truck wants to slow down big time. Some vibration unusual also coming from the front ent under the driver side. Yukon xl, 2000, 4x4, 5.3 litre, 90 km, This truck is always parked in the garage and rarely put in 4x4. Let me know what you think it could be. All oil level are good.
Any noises such as squeeking or chirping? May be bad u-joints on the front driveshaft.
Yeah it could be something loose. Or maybe something frozen up in the front driveline. NOT using the 4x4 on a regular basis is the worst thing you can do to these 4x4 trucks. You could have the dealership near you check out the front end for you.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
