another nooooob!!!
chopper_rich
hey guys, im a new guy here, i have a 2000 yukon denali... basically stock, but in pristine shape.
im a frame/body tech, and 28 years old, from seattle wa. into hotrods, tattoos, rock n roll, and learning new stuff.
glad to be a part of this.
~chopper rich
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
