jhortonvt Posted January 4, 2007 Posted January 4, 2007 I have an "02 Silverado and when I push the AWD button or use the 4HI button I get some resistance noise from the front end, especially when turning. It's more than just the expected resistance you get when using 4WD. It's like there's a bad U-Joint or bearing or something. Any ideas?
cerbomark Posted January 8, 2007 Posted January 8, 2007 the resistance is normal, the noise is not normal.
ZZ327 Posted January 9, 2007 Posted January 9, 2007 If youre doing that on dry pavement, you arent supposed to be! It could be a U joint otherwise.
