Can You Identify This Piece/Problem?
tim73
Its off of an 8.1L GM engine. I pulled off of the throttle body, to try and fix an idle surge. It had a schraeder valve under the green cap inside it(Almost like a fuel pressure relief valve).
BTW, after cleaning out the throttle body, it did seem to help some, however, it is still doing it some. Initially I thought of the IAC valve, but I could not see it anywhere. This is my first GM, always worked on fords.
Thanks in advance
I cant identify the problem but that green cap covers the EVAP system test port. It is used to vauum test or smoke test the evap system to find a leak.
  • 8 months later...
