Trans case noise
WillyT
Just purchased 2005 2500 HD, 15,000 miles, electronic transfer case shift. Upon shifting into 4X4, there is very noticible "whine." I understand that it should not make much noise at all, as my 1999 Z71 makes little to no noise either. All seems to work fine, it is just very noisy. Is this fluid problem? What is worst case scererio?
Change the fluid and see what happens. I changed the DexronIII out of my tcase and replaced it with Mobil1 Synthetic ATF. I noticed that the tcase was about 1/4 qt underfilled from the factory spec as was both front & rear diffs. Fillled all to factory spec and my drivetrain noise has reduced by about 50%. I would change your tcase fluid first because it's easy and inexpensive if you do it yourself. Then run the tcase for a few miles. If the first owner never turned it on it may just need to run a few miles to loosen it up.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
