Transfer case shift knob removal?
gatorz
I have a 1997 Silverado with a floor shift transfer case. Over the years the plate that lights up when you engage four wheel drive has become a little dilapidated. To replace this I have to remove the shift knob from the stick. The knob does not seem to screw on like most shifter type knobs. How can I remove the knob without causing damage to the stick or anything else that is more important? I can replace the knob if it breaks but I don't want to hurt anything else. This truck is in mint condition inside and out (only 21k on the clock) and little things like this plate paint starting to crack bothers me. Any advice or direction would greatly be appreciated.
Thanks
Joel
  • 4 months later...
Remove the screws that hold the cover to the floor, lift it up, and you will see where the shaft unbolts. the knob itself does not come off.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 874 Guests (See full list)
