Difference Between Moon/Sun Roof
chud53
ok just a quick question, what is the difference between a sun roof and a moon roof??? This has been bugging me for quite some time cuz they seem to be the exact same thing to me....HELP
Used to be that moon roofs were glass and sunroofs were metal.
The term sun roof is more popular nowadays though to describe the glass ones, seeing as the metal ones aren't all that common anymore and sun roof sounds better.
The term sun roof was more popular in the 70's. I think people in the hotter states were not buying them thinking the sun was going to scortch them. The auto makers started calling them moon roofs in the 80's which sounds more exotic and does not sound like you will be getting sun burned.
Uh, the term 'moon roof' was started by Ford, in the 70's.
OK if you say so. I just remember in the 70's sunroof was the most common term. I recall moonroof being first used in ads for luxury cars during the 80"s. Basically they are interchangeable terms now.
It's a "sunroof" when you open it on a sunny day, a "moonroof" when you open it on a clear night, and a "cloud roof" when you open it on a cloudy day. And when it leaks, it becomes a "leak roof". Any more questions? :)
Sunroof
From Wikipedia, the free encyclopedia
A sliding glass moonroof on an Acura IntegraA sunroof is an opening in an automobile roof. Sunroofs may be either fixed or operable.
Historically, sunroofs have been opaque and open to the air to allow the sun to shine directly into the vehicle, while moonroofs have generally been transparent or semi-transparent and designed to remain closed while allowing muted light to penetrate the vehicle.
Variations have become the norm and often combine the features of the Sun and Moon types into a single device. It is not uncommon to see tinted glass that can retract fully like a traditional sun roof, remain closed like a traditional moon roof, or tilt to allow for airflow.
Modern implementations often include a sliding shade that usually matches the internal roof upholstery and provides a way of essentially hiding the sun/moon roof behind it. The American Sunroof Company is often credited for creating the modern moonroof.
Sunroofs can be manual or electric. Manual sunroofs are usually flipped up to create a small opening around the edges, or are removed completely. Electric sunroofs either flip up and slide back on top of the roof, or down and into the roof. An electric sunroof will have the facility to be closed manually if the motor or control circuitry fails.
Thats what I was thinking.
It's a rarely used, poorly engineered device that reduces interior headroom by 2 or more inches. Fricken $50,000, 6,000 lb. truck and my head rubs the ceiling. I'm only 6'-2"!!!!! d**n the "soccer Mom's needs first" panty waist designers at GM!!!!
sunroof/moonroof/astroroof/holeintheroof/etc. It depends on what marketing or advertising person or firm was hired to promote the option.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
