Horn Problems
Hello Gents,
My name is Lou and I came across your forum while doing a search.
I got an 03 Silverado 1500 4x4. Its got about 42k on the clock and for the past month I have not been able to keep from blowing the horn fuse. :banghead:
About 3 weeks ago a co-worker and I tore into the colum and i was able to locate the harness on which the power to the horn is fed. After some moving around of wires, disconnecting and reconnecting the harness I was able to keep the horn active. So i thought, Ok it must have been grounding out. Well less than a week ago, while making a right turn I leaned on the horn ( I'm a volly Firefighter, was on my way to a call, lights flasing and an old timer refused to get out of my way) and after a quick toot the fuse blew again. I just wondering if anyone else has had this problem and if it was fixed, what was found to be the cause? :jester:
Thanks, Lou
www.freewebs.com/stmoritzguitars
Your problem is not at the column because the wire going to the horn button is the ground for the relay. Look at the wireing from the horn relay to the horns. Possibly a bad horn or a wire grounding out.
This may be a little different but i put an aftermarket horn in my truck and the horn fust kept blowing. The new horn pulled a little more juice than factory but not that much. I just threw in a slightly larger fuse and havent had a problem since. Just my two cents.
Thanks for the info Gents......As soon as i get a chance i'll check it out and post my findings !
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
