Improving MPG on 8.1
The only thing, in my opinion that keeps the 8.1 from being the PERFECT truck is the fuel mileage.  Some of the things I have thought about to improve my mileage (which is 9-10 mpg..mostly city) is the K&N Filter Charger, aftermarket muffler, and tonneau cover for the bed.  My question is: has anybody done anything to improve their mileage and succeeded?  I'm thinking maybe the Hypertech Programmer might help with MPGs too?  Anybody done it with the 8.1?  Is there anything to those Helix power tower things?  Looks like a gimmick to me, but I've never found anybody who has tried it.  Thanks in advance for any help!
Mileage with the 8.1 is not an issue.  unless you're a boulevard cruiser   If it is... the mistake was in the prepurchase decision.  Should'da got a diesel.
I don't mean to flame here .. but anything that is a significant mileage increaser ... like rear axle ratio, bigger tires, etc reduces the 8.1 capacity to haul or tow.
The bed cover will help with the air drag ... but costs a bunch up front.
hosspuller,
Well mileage is an issue with me.  I'm not sure my truck is a boulevard cruiser as much as it is a 'family truckster'.  That is untill I load it down heavy or when I occasionally hook up to a car hauler.
I am just looking for folks who have done any of the mods that I've mentioned and have seen increased mileage....or if they have any other suggestions (short of trading for a diesel).
I'm sorry.  You bought a 4x4 Crew Cab pickup with the largest displacememt engine available in any pickup and an automatic transmision and now you've got a problem with its fuel consumption.  Let me guess, it also has 4.10 gears.
I think you bought the wrong tool for the job, but at least you didn't pay for the diesel engine.
A 1500HD will carry virtually as much bed load as your 2500HD and get 50% better milage in the process.  It will also tow the car hauler (Unless it's a 3 car hauler) and has exactly the same cab.
If you buy the Helix then W.C. Fields anticipated your birth. "There's one born every minute."
Even if you only get 9 MPG and you drive 1800 miles a month (which is high) you're only buying 200 Gallons/month of fuel.  If you got 12 MPG (which would be a miracle) you'd still be buying 150 Gallons/month so at most you'd save 50 Gallons x $1.50/ Gallon = $75/ month which means you'd better not spend much trying to improve your fuel economy.
Drive it less...use the other vehicle to haul the family and it'll burn a lot less fuel.
I'll bet that you could do all the mods listed and still not get over 10.0 MPG in the city...none of those things will help at low speeds, and they might even hurt.
Your truck is very, VERY good at what it was meant to do, but it was in no way made to be an economy car.  Having put some miles in behind a 454 I'd have expected worse than you are getting.
I have 38k miles on my 01; Highway driving. The best mpg was 14 mpg setting cruise on 70. I do have a bed cover, no other mods though. The worst is city driving and it is 9-10. I am used to it now and I try not to think about it. My next HD will be a diesel. I plan to get at least 200k on this one before I change.
dmason57,
Thanks for the cordial reply.  I've actually gotten about 13 on the highway and thought that was pretty good.  I've talked to some guys with the 6 spd and 4.10s that say they're getting 15.  I consider that downright incredible.
Colorado Kid,
Thanks for the math lesson and all the other great advice, but you should re-read my original post.  I happen to like my truck alot.  The fact that I sometimes get 185 miles from a tank of gas seems to me to be the only thing keeping this truck from being an absolutely perfect truck.  I've had two trucks with 454s.  I'm familar with poor mileage.  I'm simply looking for some ideas on how to squeeze some extra mpgs out of the 8.1.
I can't blame anyone for wanting more mileage out of a big block.  I bought mine knowing that double digit numbers would few and far between, but I could handle a mpg or two increase.
I picked my truck up this afternoon and have realized that I should measure fuel consumption in gallons per mile.  Regardless, I'm happy as a clam and if this thing is as reliable as the wife's half-ton, I'll be even happier.
Of all the things you have mentioned the bed cover will help the most, reduces wind drag.
The other thing you might check is running the Direct Hits ignition system, some of the 8.1L AV folks have tried this and results have been positive. You can get it at TByrne Motorsports - one of our preferred vendors :thumbs:
BTW; oil and gas consumption settle down after about 5K miles, even better at 10K, and synthetic will also help and doesn't cost an arm and a leg.
You could trade it in on a S-10 crew! j/k
I am getting 9 mpg, 75% city.  That is why I have a car, too.  This is with a tonneau, 3.73 rear, gentle right foot, but 255/85's - they cost 1 mpg.
On the other side, there are a few things to try:
 -tire pressure - maintain high pressure (65 front, at least 55 rear when unloaded), it will ride a little rougher, but roll easier.
 -switch over to 87 octane if you are running something higher.  The gas was good for about 1 mpg with mine (ran premium first 5K, didn't believe it until I actually tried it).
 -keep top speed below 70, if you can.
Besides, think how muck gas $200-300 will buy vs. something that may or may not get you 0.5 mpg better.
In the original post a Hypertech Programmar was mentioned. I have two of them and can recommend them as being an excellent product.  The problem comes in when you have to buy high test (92 octane) fuel to run their best program.  I have gotten slightly better mileage doing so but not high enough to justify the additional cost per gallon.  For my Tahoe and Z71, their programmars did provide much better towing ability with a very heavy trailer ....but with the 8.1, that isn't a problem. :thumbs:
LOL!!!  I love when people ask me what I drive and I tell them, an extended cab, 4x4, Silverado 2500HD with the biggest gasoline engine available in anything that would be considered a passenger vehicle which then spins through one of the toughest light to medium duty transmissions available on the market.  Their comment is always..."oh, you must get TERRIBLE fuel economy/mileage with that!"
Well no sh*t Sherlock!!!  I didn't buy it for fuel economy.  Fuel economy was the furthest thought in my mind when I purchased this thing!
Other than spending money on big things like a bed/tonneau cover or performance parts that will allow more effective combustion, simple maintanance will help.
Make sure the tires are pumped up more as they will provide less rolling resistance, keep your fuel system clean (I.E. change filter), keep your air filter clean, keep all fluids routinely changed (I.E. oil, trans fluid, rear end fluid, etc).
Yesterday I drove to Bloomington, IL.  Before I left, I filled up with 14.221 gallons of gas.  When I got to Bloomington, I had 114.3 miles on the trip odo and I used approximately 1/4 tank (1/2 what I filled up with).  So 114.3 miles/7.1 gall = 16.076mpg.
On the way back that mileage dipped back to 11mpg but that was due to me disciplining a Pontiac A$$tek at triple digit speeds.  The G/F hates when I bounce it off the speed limiter.  :thumbs:
I'm sure you could improve your truck's fuel mileage, but at what cost?
Performance Combos runs ads listing various hop-up combos, their theortical HP/TQ improvements & prices for same. Might provide some idea(s) on where to start.
Drawbacks to increasing tire pressure would be reduced tire life (centers will wear out) & possibly harsh(er) ride.
I've seen ads for Jacobs Electronics ignition systems that list HP/mileage before & after for a '90 454SS. Here are the #'s:
Before: 230HP/16.52MPG
After:   242HP/17.75MPG
Don't see how a 454CI/7.4L engine ever got 16.52MPG to begin with, let alone 17.75MPG but ... those are the #'s. Take them for what they're worth.
Good luck.
Some of the items mentioned on this forum (as well as a few others) are:
- mass airflow sensor
- throttle body spacer
- increased air intake (K&N or UPD)
- new exhaust
- new chips
There seems to be a bit of controversy about which of these provides what benefits, but they may be worth investigating. A new chip seems to give the most benefit, but as expected, is one of the most expense (the most expense is probably exhaust changes).
Guest Friz
Hey, you guys back off!
Just because we buy big trucks, doesn't mean we aren't concerned with making them a little better.
Trying to get a few more mpg from a crew cab big block is no different than trying to squeeze a better 1/4 mile e.t out of a vehicle with the aerodynamic qualities of a phone booth!
Garmat, I have looked at this problem for a long time with my 1 ton CC 4x4 350. I figured, based on what I'd read here and on other bulliten boards, that it would cost me around $1200.00 to get my highway mileage from 14 to around 16. $1200.00 will buy a lot of gas. I just decided to live with it.
    Zinister101
    Zinister101
  • Who's Online   5 Members, 0 Anonymous, 664 Guests (See full list)
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
