Volant CAI
I have a 2003 silverado 3500 with a 8.1. My question is that I am wanting to put on a Volant CAI. All I can find is the ones that are listed for the 2500 series,will they fit the 3500 or not. Thanks for the help.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
