2006 Silverado
redfishninja
I have a 2006 Silverado crew with the 20" GM sport wheels. It has a torsion bar front end. I have
12000 miles on her. My font tires keep getting feathered. Also I have a front end alignment problem
that keeps popping up. It needs a another alignment. This would make 3 total at 12000 miles. What
would be some causes to make the front end to go out all the time. I had my first Chevy (2000 Blazer)
in the shop 12 times for re-occurring problems. It looks like I will be at it again. This weekend will be
round 4 with the Silverado. But for real. I think my local dealership recknitions can't figure it out.
Help!
Doug
