Ford
Chev4Ever
Can someone summarize all the fuss thats been going on lately with Ford? Thanks I just dont quite understand it.
                                                            :stupid:
Blueovalnews.com suposibly has papers to prove Fod lies to the consumer and government.
Also, their sales are way down.
heres my opinion on the firestone issue (what most of the lies are centered on)
ford took the responsibility to replace the faulty tires which they did not even make...did firestone do anything?? No!  firestone didn't care if hundreds died b/c of their faulty tires.  GM would have done the same as ford did. now the explorer was not the best in rollovers, but it was not directly related to the vehicle.  basically people should not put all the crap on ford, overall it was firestones shoddy workamnship that caused problems. also in several independent tests the explorer handeled fine in a blowout situation, and only 2(i belive) tire related accidents happened on explorers equipped with good years
BTW, thanks Mervz for keeping us up to date on this stuff
Paco, Ford had as much to do with those tire failures as Firestone did.  They recommended that the tires be inflated several pounds below what Firestone recommended simply so the ride would be a little nicer.  We all know that an underinflated tire builds up much more heat at high speeds than a correctly inflated tire, which increases the chances of blowouts.  As you may recall, all of these tires failed at interstate speeds after extended drives, during which lots of heat was built up.  Is Firestone free of all blame here?  No.  Is Ford free of all blame?  No.  But in my opinion Ford did a wonderful job of shifting almost 100% of the blame onto Firestone, causing that company to have a ruined name forever, I highly doubt they will ever gain back the market share lost and it wouldn't surprise me if they will end up folding several years from now.
If these documents that are claimed to exist actually are true, I wouldn't be surprised to see what I just said above contained in them.
Acutally i remember watching a news special on the explorer/firestone issue.. They set it up so they controlled the blow out on the tire and they did it up to 75 mph and they were able to come to a controlled stop.. They said the main reason for the accidents was for the driver of the vehicle freaked out and lost control..
About the tire thing.
As I see it all parties involved were to blame for that one. Firestone makes a marginal tire at best. Ford took a marginal tire and put it on a vehicle that was too heavy and reccomended an unsafe air pressure. Then you add the fact that most people driving SUVs had cars prior to the suv. Remember the talk about the CJ5. It was a very good off road vehicle and when the average joe tried to drive it like there car they rolled it over. Just a thought.
This is just my opinion but, I never thought that Fords' "twin I-Beam suspension" was very good on tires.  Have you ever watched them going down a bumpy highway?  It looks like they are sawing off the front tires as the front end moves up and down....  The tracking width appears to change by several inches!!!
Quote from Chev4Ever, posted on Oct. 03 2001,9:20
I saw the same news special. The thing they didn't tell the viewers is what pressure the rest of the tires were at. Some others on this site including myself have noticed on our BFG's that from 40 to 50 psi there was a big difference in handling. I am staying at 50 psi, it handles so much better. On the news special, they may have had the tires at the correct psi, but most Explorers don't. Not ruling out panicking, but this may have something to do with it also.
Ford has the right to chosse their suppliers. When they use a suppliers parts in their product, the consumer can expect Ford to stand behind it. The people that bought these vehicles didn't buy them from Firestone. If your bumper didn't work correctly would you blame Ford or the bumper manufacturer? Any company has responsibility for their entire product. Even the parts supplied to them by their vendors. Consumers should only deal with Ford, and then Ford should deal with Firestone. Ford has to be held accountable for the suppliers they choose.  This applies to all companies, not just Ford, and not just automotive.
I had the Firestone Radial ATX IIs P235/75R15's on my '93 F-150.  The biggest thing was the air pressure.  They could only hold 35psi.  They always looked flat.  The handling was better than the Cooper's I have now.  I think that was a major factor in the Explorer issue.  I know people that have been driving Explorer's for along time, whined about poor handling, and got new tires from the recalls and tell me the handling has improved dramatically.
In the 7.5 years I've owned my '93 F-150 I've only worn a set of edges out on tires.  I blaim that on not rotating tires correctly.  The Twin-I-Beam and the TTB both require alignments occasionally.  I've had my '93's aligned twice since it was new.
yes, maybe ford had a part in things, but there were MILLIONS of faulty tires and ford replaced ALL of them, firestone did not replace a single tire free of charge.  also, like i said before, there were only 2 accidents similar to the firestone ones on explorers equipped with good years
also several tests have been done by independant companies proving the explorer was not the main reason for the accidents, like Chev4Ever said, it was just people freaking out who had little or no idea on how to control a vehicle in a blow out situation
another factor was prolly just poor vehicle care...many people who buy explorers are not the most car-intelligent people in the world, many probly did not change the tires or fill them with air when needed
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
    • Do you have access to BP fuels? Some stations have Silver 91 E-0 priced the same as their 93 E-10.  There is a local Marathon with 90 alky free for $6 a gallon but I go down the road to BP for $5-ish. They also have a 100 E-0 but that stuff is $10 a pop.
    • Consider me amused. We are who we are, right?
