I have a 96 sierra 4x4 5.0L. I haul a trailer with two quads and one in the bed almost every weekend. The rear of the truck squats pretty good. What can I do to make the rear end from sagging too much?
Helwig makes both a constant as well as progressive setup for helper springs, they work well. Also Timbren makes a really neat and easy to install system that uses your bump stop mount. Both will fix your problem with ride height. Now for the Dad section, if you do this all of the time, seriously consider upgrading your brakes. This is a huge safety issue if you are towing at the limit, also a BIG tranny cooler is money in the bank. Good luck.
