DTC codes
Tim Chizo
I'm having a couple of codes pop up when I get the check engine light on and they are not in the book.
P7400 Manufacturer Specific
P9600 Manufacturer Specific
Pff00 Manufacturer Specific
Anyone have an idea what these are?
Thanks
I have checked GM service manuals and those codes are not listed and I have never seen them. Try a different scanner.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
