Cold Start problem
jferrell
2002 silverado 1500 with 5.3 gas engine
Problem: doesn't want to start in cold weather - intermittent but colder is worse
New Parts so far: Fuel Pump, Fuel Pressure Regulator and Air filter.
Parts checked and cleaned: Fuel Pump Relay, all fuses, OBD pending codes, IAC valve, throttle body.
Fuel pressure readings (two tests in 40 degree weather, listed in order):
cold before starting: 54 and 57 PSI
running: 49 and 52
shutoff: 48 both times
5 minutes after shutoff: climbed from 48 to 58 and stayed both times
retested with gas cap on and off - no change
After starting: runs like a champ at all times.
Owner: frustrated.
That's some pretty incosistant readings. Does the fuel pressure hold when you shut it off, or does it drop? Did you check the fuel filter?
I forgot to mention the new fuel filter - that's been updated in the post. Notice in the post that when shut off, there is a slight drop to 48 (normal by my shop manual) and then it creeps UP to 58 and stays. The book has you looking for a steady state or a drop of no more than 5 PSI over 5 minutes. I don't know what happens overnight, as I've not left the guage on. When I attach the guage, I of course relieve the pressure first.
I'd still suggest that those fuel pressures are low. Most times when I encounter a hard start issue with newer vehicles, anything less than 55psi and it's a pain to start...more than that and it starts with no issues.
Is there another likely cause for low pressure in cold termperature? I want to try it all before I go after the pump.
Had a similar problem on a Sierra 1500. The symptom was hard starting, but if the key was turned on for 10 to 15 seconds before activating the starter, it started easier. Once it started, it ran great.
Changed the fuel pump, filter, and wires at different shops. Then the fourth try was the fuel regulator (mounted on top of the engine, drivers side). After $400, turned out to be a $20 part.
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 743 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
