2006 alignment
redfishninja
I have a 2006 crew cab with 20" gm rims. The front suspension has torsion bars. It keeps getting a
pull to the right. 12k miles and I need a 3rd alignment. Any ideas what keeps making it go out of alignment?
Doug
Doug
Have the tires check with a road force tire balancer machine(the dealer should have one,if not try another dealer),if one of your tires is bad it will cause the alignment pull,if the tire is bad then you will need to get it warranty and set the alignment to factory spec's,a common mistake is to continously adjust the alignment to compensate for a bad tire.If the tires are the original that came with the truck then they are under warranty and it should cost you nothing to get it repair.
Try swapping the front tires from side to side and if the pull changes direction, the problem is your tires not the alignment.
